There's much more exciting updates now! Lot's of cool progress, it should be drivable tomorrow.
I was warned about the frame coating being difficult to remove so I tried aircraft remover. It worked great, spray it on, wait a few minutes, scrape off the majority of the stuff, reapply and wipe off with paper towels. Only took about 30 minutes to clean both sides!
After all the aircrafts were removed, I cleaned up the frame with a 7" cutoff wheel and a few 4.5" flapper disks. Ready to start putting on the new stuff!
After talking to WFO I decided to go ahead and get their steering box brace. It's a nice unit and restores some of the strength lost when you cut out the front crossmember. The dropped pitman arm from their 6" lift kit is also pictured, it's necessary since I went with the 6" kit track bar.
The brace even has a spot to put the 4wd actuator so you don't get a CEL.
The next step was to clamp and tack weld in the frame plates.
I had to slowly work around the plates switching sides and taking brakes to prevent warping, and killed time by installing the shock mounts and track bar mount. Here's the money shot with everything welded in place.
I welded the brake line brackets on and sprayed everything I could hit with a nice coat of paint.
To prep for tomorrow, I welded in the tube adapters for the links and adjusted them to the recommended length according to the directions and put the rod ends into the track bar and tie rod ends into the drag link and adjusted according to the directions.
Tomorrow morning we'll stick the axle under the truck, bolt up the links, set the caster and tack the mounts in place, cycle the suspension to make sure I get the axle where I want it, then weld in the bump stops.
Then I'll tear everything apart, finish welding and paint the links and put the whole thing back together. I'm guessing I'll be able to have the links painted and drying by lunch time and the truck will be driving before I have to work tomorrow night (5ish). I'll still have a pile of little things to finish up, but it will be mostly done and drivable!
