I got to "work" from home today and spent about half of it in the garage to make up for lost time. I painted the housing, reinstalled the carrier, replaced the ball joints, reinstalled the knuckles and installed an ARB diff cover, all without taking any pictures...
If you've never worked with a newer dana 60 (I hadn't), they're kind of a pain in the ass. I rebuilt the shafts, which starts out pretty standard, clean, paint and replace the u-joints.
Then you have to use a special tool to install the "vacuum seal" that seals the hub/knuckle to the shaft. First put the axle in a vice, slide the seal on, put the tool on, then beat the crap out of it until the seal is fully seated on the axle. It laughed when I tried to use a dead blow...
Once the seal is on the axle, lube up the seating surface with anti-sieze, slide it into the housing, make sure you get the splines lined up, reinstall the tool and beat the crap out of it until it's fully seated.
Here's where the axle sits now. I'm having a new set of unit bearings machined for the Chevy pattern, then I can finish it up.
I forgot to mention it in the previous post, but you can see the WFO coilover mounts installed in some of the pictures. They're pretty slick, they bolt on where the coil bucket was, then you weld the top seam to keep them in place.
