There is another issue I've run into and I'm wondering if any of you guys have any ideas. While I was on my way to Sunflower Mine, there are a few decent hill climbs. I wasn't really paying attention to my gages because I didn't have a trailer and it's winter, typically I'm only limited by water temps on these hills when pulling a trailer and never really have to worry about EGTs.
I just happened to glance over at my Edge CTS monitor to check the water temps and saw my EGTs well over 1600F, I had just been cruising up the hill with the cruise control on so I tapped the brakes and let the EGTs come down. Obviously I didn't melt a piston, I didn't hear anything wrong or feel any drop in power, everything seemed completely normal.
I dropped my tuner down to 1 (+25 hp, it was on 2 which is +50) and I watched the monitor like a hawk after that letting off the throttle , and I've taken the truck out one more time (pulling a trailer with the S-10 on it) and the EGTs just climb like crazy, I was seeing 1400 at 15lbs of boost and 1/4 throttle. I can easily spike the temps well over 1400F, I have my tuner on the lowest level (+25hp in theory).
I did some research and found that apparently the Edge probes are crap, so I ordered a replacement US made one with the right pigtail (
https://www.amazon.com/gp/product/B07BHYH3PW/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1) and installed that today. I took it for a quick test drive and I can shoot EGTs past 1400 in 3rd (ZF 6 speed with a granny, so it's more like 2nd in a normal car). Any amount of throttle pushes the EGTs past 1000F.
The truck really isn't dumping black smoke, in fact as the RPMs come up and the EGTs climb the exhaust clears up.
If it was a bad injector I feel like I would have melted a piston already, if it was accurate, I also feel like I would have melted a piston or 8 when they hit 1600F sustained. I have a stand alone Autometer gauge that will be here on Monday, but I wanted to see if any of you guys had an idea.
This whole thing did inspire me to finally do all the other engine upgrades I wanted to do, so I'll be posting that here soon. I've got a Mishimoto radiator and intercooler on the way as well as ARP studs, new head gaskets, new intercooler piping, down pipe (thanks Jack!) and I plan on getting my injectors rebuilt and the turbo rebuilt with the wicked wheel while I'm at it.
Let me know what you think. I'm really hoping I didn't trash my engine. It still drives fine, isn't dumping smoke or fuel out the exhaust, power delivery seems normal, sounds normal, but the EGTs are scaring me.
