"in crowd"
Pssshhhh.... Now your just talkin' crazy!
"in crowd"
i didnt know how close his shop was to the border..just being nosy and trying to keep with the "in crowd"lol...
Chris - In all reality, if I had to do it over again, I might build a taller rig. Sitting on top of the drivetrain rather than next to it would have made things much easier to build. I'm also not sure that I really lowered my COG all that much. All of the heavy items (tires, axles, drivetrain) would have stayed in the same place. The only weight that would have really gone up would have been a few tubes and a couple hundred pounds of driver and passenger.
However, it's not like anything I've seen before, so that certainly makes up for a lot of it. I just hope that the weight distribution is good enough that I don't end up shying away from some of the nastier hill climbs.
Just out of curiousity, what does your rig measure to the belly and what did the WB end up at? Do you end up using your skid quite a bit in Colorado? From what I've seen of CO, it looks very similar to the Iron Range here. Moab is so different from anything else that I don't think it would apply to the local terrain.
*makes mental note to reinforce the bottom of the chassis*
IIRC I'll be at 27"ish to the belly. WB is set at 130". The upside is that once the front axle is clear, it's smooth all the way to the rear axle.
Still a little bit skeered that my breakover angle is going to phuck me more often than the low COG is going to help.
130" WB is big but the 27" belly height is really high too.
You'll be fine. Besides, as long as the belly is smooth, you're never hung up as long as you have enough horsepower![]()
Seemed like kind of a waste to be any lower, considering at that point the belly would be at the same height as the axle tubes.
I kind of have the hankering to do something stupid with a couple of turbos and a megasquirt. That's after I find room for a 20 pound bottle of happy gas.![]()
49" tire means a 24" center or so, minus half the axle tube diameter would seem like 22-23", right?
How much fun would that be![]()
I like it.
No wonder it's taking a little time to build.
What's your weight ratio f/r gonna be?
Each end of the buggy will have approximately 1200 pounds of unsprung weight.![]()
I think that is MikeyI heard it was one of these
