2012 Chevrolet Caprice PPV
For real? I've got a new Cloyes 94205 already on order, arriving in 2 days. If it's still this sloppy, I may return it
Edit: Nope, he's right. Apparently they are just that loose. Weird! I'll run this stock 7,000 mile chain with the plastic block as shown.
If that's old and the cloyes was already there then :dunno:
But yeah, they just are that sloppy and it gets everyone that gets in an LS I think lol
Yes LS chains are notoriously sloppy vs an old SBC or BBC chain. This is why I always put a better one in, like a Howards or a ProGear. But its not really necessary on a stock engine.
Making a little progress. My goal for yesterday was to remove the radiator, which I eventually did.
The worst part was loosening the 2 Torx (?!) screws holding the front plastic belly pan onto the plastic inner fender wheel wells. Good lord, those things were bound and determined to stay put. Ruined the bolt head with Torx and allens, and its low, rounded profile made it nearly impossible to get pliers or vise grips on.
So I eventually cut around one of them with tin snips and will just zip tie it or something when I get this all back together.
Another thing that's confusing to me, since I haven't worked on late model GM stuff very much, was the c-clips holding hoses together. Hardline trans cooler hoses into the rad use a tiny metal clip to hold them together, so I had to run and buy a set of picks to remove them.
And I promptly lost 2 of them. So small, you can't even hear them hit the floor.
Today's goal is to remove the cowl and make more progress.
Any thoughts on other parts to replace while I'm swapping motors? I already have a new water pump for the swap.
I'm thinking radiator hoses, heater hoses, belts, tensioners, but what else?
Ah yes, I have motor mounts. Good call on them.
I hadn't thought of header bolts. I'll pick up a set
Perhaps you are already aware of this, there are also "Torx Plus" fasteners that require a bit that will be called Torx Plus, sometimes abbreviated TP or T+. If you use a regular Torx bit on those it can strip them out before they reach full torque. This is why sometimes a regular Torx bit doesn't fit no matter which size you use. So I would get a set of TP bits and always see which one fits better before you crank on it.
Likely needs a rebuild, and I ain't got time for that. Plus I like my GM Goodwrench 350 and Quadrajet in the Jimmy. I just passed emissions no problem after smooth operation for the last 2 (!) years.
Knock on wood.
lemme know if you want to off load the l77 for a reasonable price
