Is it a fixed vibration or one that oscillates on and off?
Does the tach needle vary at idle when this happens?
It's really more of a shake and it's fixed. Coming on at 70mph and gets worse to 75 and stays about that bad. Tach is steady.Is it a fixed vibration or one that oscillates on and off?
I doubt is bad enough to see at the hub but maybe I could runout the wheel lipThis will be interesting to see the results.
Did you put a dial indicator on the old axles to see if they were bent?
That’s my thoughtsSounds like a known issue. Why else would they offer that package?
