Jason4x4
Once Again, If you don't want to see what he is doing, stay out, no one is forcing anyone to read this thread, he has some good Idea's , leave the guy alone and let him build. I would like to see how his burb turns out.
Lookin pretty good so far. Does your arm have the taper machined into it?
For the Kingpin rebuild kits check out Highhonda on Pirate. he had the best deals I found anywhere for all the dana 60 stuff.
I'm usually not one to chime in but that's pretty much showing your age. I know you're gettin a bunch of **** but you can scroll past those posts as easy as read them.
Just IMO![]()
Just IMO![]()
Well, Howidy did start it this time, and to someone who was commenting on Howidy behalf. If he is going to make enemies with people who give him some support, he is going to have a hard life after high school.
I'm making enemies with people that support me? Please do tell
I'll check out high honda. No taper machined at the moment, I'm having my dad check and see if his friends machine shop can taper holes, if not It's getting a 1" heim, hopefully someone can drill a 1" hole for me.
I guess I need to keep an eye on this thread. If this crap continues, I'll simply lock and delete it.
That goes for everyone involved in these shenanigans...........![]()
No I didn't mean the taper in the hole. I meant the taper in the top of the arm to counteract the ackerman angle. If it's just a piece of flat bar the angle of the Heim/TRE will be nearly maxed out while its static.
You can see in my pic the surface the draglink connects to is angled different than the surface on the top of the arm.
Too thin...every stop and wonder why everyone else makes them so beefy?
If you're gonna fling crap at other people's work I recomend not putting up pic's of stuff that 'ain't done'. At this point it seems you're now saying they're not done because I pointed out a major design flaw (as they are now). Up til this point you've never mentioned they weren't done...seems pretty convenient.
Rene
The bracketry is much stronger than the frame itself
And flinging crap at others peoples work? It's not as if I went on the prowl to **** on peoples work. You seem to have forgotten this is indeed the thread about my truck.
But like you said it is actually all my dad's idea's, obviously
How are you addressing this then?
Those arms look nothing like what you built. Frankly I'd still take billet over those.
As for 1" bending like paper...nope. However I will concede when you show me where you used 1" thick material. Your laminate is quite inferior to 1" IMO.
What grade of steel did you use? As for the other laminate arms I can only assume looking at the welding and fab quality that they didn't use scraps of mild they found behind Dad's garage.
Rene
"WHEN"??howdiy said:When it fails I'll get a billet one
That's probably the dumbest thing you've said yet. If this ever sees a road i hope you don't kill anyone cause someone else already predicted this
