sandawgk5
3/4 ton status
There is no reason to lock this thread. If you dont like reading then the internet is not the place you should be looking for info.
Threads like this happen all the time it is just part of being here like when brothers beat the **** out of each other and then go hang out when it is all done.
Ira
Threads like this happen all the time it is just part of being here like when brothers beat the **** out of each other and then go hang out when it is all done.Ira
) now you're saying that you used the ground off calipers. i'm not sure what part of the function of those tabs you didnt understand. they are there to keep the lines from working loose. now that you've sucessfully removed them, you're no better off than you were when you were missing a spring pin. (you do remember that you were proven wrong there right?) sure the calipers dont leak now, but give it a few weeks of driving, and i'd be willing to bet that they calipers work loose, or at least the lines move, from road vibration.
