3 inch lift using 2inch suspension lift and easy inches
JFHblazer
Registered Member
Texas
Purchased an 86 m1009 that has no mods and would like to start my resto on it by first lifting and extending a little.
Want to do the following: Lift 3 inches push axles back 1 to 1.5 inches and slap 35x 11.5 or 12.5' under it. I plan on cutting both front and rear to fit the tires. This is nit going to be an rock crawler so do need so crazy clearance.
Questions: Is 3 inches achievable using this method? Are there brackets I will need to move the sway bar forward?
Solution
Caster has a lot to do with return to center. Before you go after caster, check that ball joints/king pins move freely. If that are binding this stop return to center.
You want positive caster +6°ish.
Solution
