Maybe I already posted this in your thread, but I used the switch when I had a 700r4. I tried the vacuum switch, but I didn't feel like it operated correctly. It's a little bit of a pain having to remember to use. Mostly I would forget to turn it off and when coming to a stop the drivetrain would start bucking. There's those couple of seconds when you like what the...? then remember to disengage the TCC.
I can also say, if you have an engine with enough grunt, it's nice to be able to lockup the TCC when it normally wouldn't. One place I used it a lot was pulling the high mountain passes in 2nd and 3rd. Usually I could hold a steady speed in 2nd or 3rd and locking up the TCC kept the trans at normal operating temperature.
As far as the IAC and engine dying, I'm only having trouble when the engine is cold first thing in the morning or after it's been parked all day at work. What I did was set the IAC at 5-6% IN GEAR not park. One of the PF4 techs, Nate S, had posted on the PF4 forum that it could be done either in park or gear. Now it operates like I expect an EFI automatic vehicle to. In park it idles at about 750 RPM with IAC at 0%, then in drive it drops to 575RPM with IAC at 5-6%.
My starting point was where the idle speed screw needs to be for the engine to idle at 750 RPM in Park with IAC at 5-6%. I put the trans in Drive and then dropped the target idle until IAC was at 5-6%. That's been working good, as I said the only time I have an issue is cold engine put into gear the first time. If I 2 foot it for the first shift, then it's fine.
