I don't know if you think the HEPA filters take out anything other than particles. Your throught is scratchy from the fumes, you need to see what can if any filter these out.I plan to run any interior parts out of ASA because of the UV resistance vs ABS. I have designed a angled mount for my Holley ProDash that is a two piece sandwich style. I just need to tweak the dimensions.
However, I am at the point where I won't run PLA or PETG, or any plastic 3D print, without external ventilation either. I don't feel it's safe after getting scratchy throats and mild headaches from PLA even with a HEPA filter on the exhaust. I think a lot of the fumes come from the purging. I plan to put an enclosed purge container on the back instead of the chute.
That is easy enough. But it helps that the new version was based more square and less round.@kennyw Any chance you would revisit your original method back on the first page of this thread? I love this design and how you've iterated it, but in it's current form it is too large for my printer (230x150x150mm area). If you made a version that could be printed in 2 pieces and glued together that would allow me to print it myself on my old printer![]()
Try it out and let me know how it works for you.@kennyw Any chance you would revisit your original method back on the first page of this thread? I love this design and how you've iterated it, but in it's current form it is too large for my printer (230x150x150mm area). If you made a version that could be printed in 2 pieces and glued together that would allow me to print it myself on my old printer![]()
Care to modify how you uploaded the stl files? It looks like you uploaded them as multiple pieces in one stl file and for whatever reason the slicer I'm using does not like it. I was expecting more of a 5.1_MP_LH.stl and 5.1_CH_Lg_LH.stl to be able to load them individually and move them around as unique objects in the slicer. As it is now, I can't do anything with itI went back through and organized everything better on that latest version. I have also added a version that is a map pocket without cup holders.
v5.0 - one-piece map pocket cup holders
This is a one piece design, 250.5 mm length on the long side and the best print results if it fits on your printer bed.
Plate 1: v5.0 MPCH, left and right w/ small cup holder, plus 4x dowel pins
Plate 2: v5.0 MPCH, left and right w/ large cup holder, plus 4x dowel pins
v5.1 - two-piece map pocket cup holders
If your printer bed is too small for the one-piece design, you can now print in two pieces and join them with dowel pins and glue.
Plate 1: v5.1 MPCH, left w/ small cup holder, plus 5x dowel pins
Plate 2: v5.1 MPCH, right w/ small cup holder, plus 5x dowel pins
Plate 3: v5.1 MPCH, left w/ large cup holder, plus 5x dowel pins
Plate 4: v5.1 MPCH, right w/ large cup holder, plus 5x dowel pins
v5.2 - map pocket without cup holders
Plate 1: v5.2 MP without cup holders (2X)
v5 - badges
Plate 1: Squarebody CHOP SHOP Bowtie
Plate 2: GMC Sierra Classic
Plate 3: CHOP SHOP
Plate 4: Chevy Bowtie
Plate 5: blank for custom text or design
I can do that. Give me a few minutes. Although, I may modify things differently to look like what I just did for the 77-80 version.Care to modify how you uploaded the stl files? It looks like you uploaded them as multiple pieces in one stl file and for whatever reason the slicer I'm using does not like it. I was expecting more of a 5.1_MP_LH.stl and 5.1_CH_Lg_LH.stl to be able to load them individually and move them around as unique objects in the slicer. As it is now, I can't do anything with it
It merges them into some odd single object. This is my attempt to open v5.1_MPCH_RH_Large.stl
I have updated all of the files with some updates. Try again.Care to modify how you uploaded the stl files? It looks like you uploaded them as multiple pieces in one stl file and for whatever reason the slicer I'm using does not like it.
That's a slick update on sticking the two parts together. Thanks for sharing it!I have updated all of the files with some updates. Try again.
Very cool. When the stock design is completed it would be interesting to add other mounting points for a b&m tranny temp guage.Pulling usable geometry from an STL graphic model and turning it into something real that I can build from is a whole new level of tedious. But I think the results will be much better fit and look when I am done than trying to blindly measure parts with traditional methods when they have complex geometry like this.
The gray circles represent the center location and max height for the gauge without any interference with the stock bezel (surface of the clear plastic cover on the stock cluster assy).
The blue surface is the back plane of the gauge cluser converted into a flat surface (green around edges is the rough geometry copied from the scan).
I still need to add two more dash bezel mounts and connect the dots and make a printable pair of plates that can be bolted together as it is too large for one print on my printer.
View attachment 521047View attachment 521048View attachment 521049
