As I'm sitting here reading this entire thread and watching Pale Rider, I have a few things running in my head that I have learned thru my project. If you have to pull the pistons, have them line bored. I did with my 400 and I have no knock at all. Ever. Regardless of timing. I bought a reconditioned crank since my old original crank was kinda egg shaped. I used my original pistons with a new Comp Cams kit which included an xtreme4x4 cam, double roller sprocket and chain, roller rockers, lifters and rods. New intake and World Products cast iron heads. Remote oil filter adapter so I could run a 2 qt oil filter and a remote oil cooler. 7 qt. Moroso oil pan, oil pump and pickup. Jegs 65k volt coil and distributor with a Pertronix ignition module. So far, works better than an MSD and quite a bit cheaper. Everything I have done to this engine has been for torque down low and so far, I have not been disappointed. If you want to run a Qjet, you will need an 800cfm one. Mine is a 750 and I am probably pushing it. Also, I have picked up a set of 81 Corvette exhaust manifolds, had them trued up and soon will be able to have my exhaust redone. I have had to deal with Cali smog stupidity so that has also affected my decisions along the way, but it also passed smog with zero problems. FWIW.No, this is very informative as this goes on. It would add alot of unrelated items to the Build. I will be adding a summary of this entire thread once I get the engine out of the Blazer and can better figure out what else is inside.
Joel
norcal
