So when my car had it's accident the hood crunched into the rad support, which pushed into the air cleaner assembly, which broke the base of the carb. I put out a parts request on another forum and a senoir member there offered me a carb "from a running 57 Pontiac". He said it's a little dirty on the outside but should be dialed in nicely. I gave $50...
I have been beating my head against the wall trying to get this old girl to start. I finally got my portable fuel system sorted out using my Blazer's overflow tank. One more potential problem area ff the list. I checked for fuel flow and got what appeared to be normal flow from the hard line at the carb. I figure maybe the in line filter in the fuel inlet may have some crud...
So, I'm thinking dis-assembly, clean and re-assemble and hope for the best. I grab my broken carb and gently take it apart hoping to harvest the gaskets and learn how it all goes together. The gaskets were fine, and my broken carb was pretty clean inside. This is the broken base...
I get all my parts laid out, a small bowl with screws and other small parts and pull the other carb off the intake and bring it over to the bench. I start pullng screws out and stuff, but it doesn't want to come apart. I keep gently working it until finally the top comes off. Tell me if this appears to be something that came off a good running car to you?
The fuel bowl...
Right now all I can think is he grabbed this carb from the wrong pile, in the meantime I'm not super happy.
Anyways, I don't have a kit here but figured I could clean and re-assemble and hope for the best.
So I hit the key and...
nothing. So far I've just been able to make shit look clean, but not actually work.
I need a carb kit I guess. The accel pump isn't doing anything, and it could probably use more of a soak.
So I thought I'd show you guys the original door panels after a bit of cleaning.
original seat upholstery...
horn/steering.
Time for dinner, then eBay and see if I can find a kit for that carb...
