Those aren't big block gaskets.
Martin
Martin
Surgeon assistant says I can’t start PT until end of February. Rotator cuff tear was unusual as it was torn through the middle of the tendon. Being that type of tear and repair requires more down time for the joint to heal. Sling time unless I’m sitting in the recliner or in the shower with the arm at my side and supported if sitting (like the armrest of the recliner). Can use the hand but no movement of arm except letting it hang down while showering. Prediction is mid June for normal use, but no heavy lifting, pushing or pulling until fully rehabbed….Here's to a quick recovery Dave!!!
.That would be tough to get used to.Surgeon assistant says I can’t start PT until end of February. Rotator cuff tear was unusual as it was torn through the middle of the tendon. Being that type of tear and repair requires more down time for the joint to heal. Sling time unless I’m sitting in the recliner or in the shower with the arm at my side and supported if sitting (like the armrest of the recliner). Can use the hand but no movement of arm except letting it hang down while showering. Prediction is mid June for normal use, but no heavy lifting, pushing or pulling until fully rehabbed…..
Ive practiced using the left hand for a couple weeks before surgery, but brushing teeth is probably the strangest thing to get used to. While brushing the right arm wants to mimic the motions of the left. Almost like it’s trying to say, “do it like this”.
Ive been pushing snow as we’ve been getting an inch or two each day. No lifting or using the right arm (in the sling the whole time) Gets me out of the house and moving around to some good crisp air!
