beags86
Eastbound and Down
What the grudge of FAST? What throttle body we're you using?It's still Mr. Bastage to you!!!
When I had the cam ground...it was done with the idea it might get a cross ram & FI.
The Holley set up is expensive but the stealth throttle bodies are tits.
This is the route I want if the money falls in place.
Tonight's lottery should cover it.
Had an old FAST TBI on the car 10 years ago. Sucked big time. Newer ones are probably fine, but I'm still holding a grudge.
& an AMC motor with a cross ram would definitely make your Chevelle different.![]()
I know fitech seems to be the hot ticket on this Forum but how much of that is because it's cheap?....
needless to say I spent the next 10 minutes backpedaling, and then got the fork outta there for a bit.
