1.75 .120wall tube sleeved with solid aluminum. Same weight as .250 wall and inThis application much stronger
I'll take it.
I feel like a thread killer in my own build thread lately.Lots of updates and photos and not much in the way of responses.
-G
Sorry.........here's a response.....
My scrap pile ain't got as much steel as what's in your rig.....J/K......keep up the good work on that hillbilly "CNC"
and OOPS you forgot to FLARE HOLE something on that part somewhere....???
I'll take it.
-G
Dude, you can get a lot more replies if you stop with this"I'm building a truck"
stuff and talk more about cookies.
Everyone loves cookies.![]()
Curios to see how the flow masters end up fitting in there. Keep up the great work
Boeshield should work awesome for a tablesaw. I've used it on mine and it makes the deck nice and slippery. It's supposed to be wood-friendly too. No oils to stain the wood and ruin the finished product.
-G
I have friends that have been denied access with both 40 and 50 series flows and they just had mild small blocks, so those 70 series do work to quiet the beast, but still let out a roar when you get on the go pedal. (their test is at 2500 RPM in neutral, so its still quite quiet, it gets loud under load) Well the holes have tubing welding inside them and will have fairly tight fitting tubing when anything is attached. I personally dont think it will be a big deal.
i'd actually bet that the tube areas will be stronger..
Look just about the right size for oreo ejectors too!![]()
I'll take it.
-G
I'd actually bet that the tube areas will be stronger..
look just about the right size for Oreo ejectors too!![]()
I just re-read what I wrote, sorry, don't mean to sound negative, you are building an awesome rig, you already know that, so let what I say go right in one ear and out the other if you want. Whatever you do, keep on going, the rig is becoming gooder every day!![]()
Heath,
Don't ever worry about that.... I really appreciate the feedback I get here from you and others here, and I'm still learning all the time. The space is really tight for my electric cut outs idea anyway, so hearing that I can safely skip it is helpful...
I noticed that flowmaster makes an 80-series muffler for BBCs too but it only comes in 2.5" versions, not 3"...
-G
Interesting.
The official GM documents for their 502 crate motors specify 1-7/8" primaries, 36" long into a 3.5" collector....then 3" exhaust all the way out the back.
-G
