bp71k5
3/4 ton status
I liked the earlier martini version better.
that'll cure the diet issue.![]()
Starting to look a little bit like the @JDNobodi truck build, eh?
Am I the only one who looks at this picture and see's the corner of the next garage rug?Same Night..... High Octane Version!
-G
What? You didn't weigh the speed holes to see how much weight you lost, you must be slacking. Looks good.
I saved all the slugs... will report back once I have all 74 collected.
.... then I'll take them to a vending machine and buy a bunch of free sodas!!!!
-G
no dimples? all you'd have to do is just drill out the spot welds, then dimple the holes.... 'just' you know, that word in the english language that has caused more wars then the words "this means war"
Here, let me use in a sentence to illustrate "honey, why don't you just paint the deck" it is not adviseable to respond with "why don't you just go to hell" and then "already there" and then "now you know how hard it is to deal with your suggestions" bad things happen after that..
I might be willing to reconsider my intractable position on this matter.The other problem is that the forming dies for a 1" flare hole are about 2" diameter, so they wouldn't fit inside that channel at all.... I suppose I could grind the crap out of them on two sides to give them the necessary clearance but I don't feel like destroying my tools for this one simple project.
-G
You know there's this guy whose motto is "why don't I just" - if this was his project, he'd already be working on the custom, one-use-only die. If there isn't a solution, then I understand not doing it - but you're already 90% of the way there with the solution.
You're welcome - I also do bar mitzpahs, weddings, and funerals.
Hey now, I didn't drill holes in my cross stills. I did however thought about.2017.05.16 - UPDATE!!! - !!! SPEEDHOLES !!!
aka. DRAINHOLES, but that doesn't sound as cool.
The factory cross-sills are a simple way to add strength (and lots of rust issues) to these early K5s.
The mostly sealed channel has numerous gaps to allow water and mud inside, but almost NO way to allow that debris to find it's way back out. My original floor and cross-sills were absolutely PACKED with wet mud and were just sitting there rotting away both the cross sill and the adjacent bedfloor metal. With such easy access to this area for the time being, it seemed like a shame not to take the opportunity to improve the design and build something that would be more impervious to the elements.
A 1" hole seemed like the right size for the job. It fills the width of the cross sill nicely, and with 2.5" centers there are plenty of opportunities for water and crud to escape. With some seam sealer pumped into all the bedfloor crevices and smoothed-out, there should be little opportunity for dirt to get inside, but obviously PLENTY of ways for it to escape if it did.... should also make it easy to get primers, paints and bedliner in those crevices as well as making it easy to hose out debris whenever I feel the need.
It took a while to get a "system" figured out for doing accurate layouts. But with a sharp scribe, centerpunch, a couple of drillbits and a fresh Jancy annular cutter a total of 40 holes were completed last night.
More than half-way done. The final count is 74 holes (for those who wish to keep track)Starting to look a little bit like the @JDNobodi truck build, eh?
This should keep me busy while I wait for the UPS guy to arrive with the next couple boxes of bling.
-G
Good idea Greg, I've maintained that a huge part of rust issues comes down to lack of drainage. Question, did you deburr the inside of the holes to allow for thorough drainage? I know that's a deburr X 74, but otherwise you could end up with a nice layer of wet against the burr on the inside...
It's not an easy holesize to deburr, I used those small cartridge-style sanding rolls and tried to lay them over at a 45-degree angle to hit the sharp inside edge. Ideally, I'd love to use one of those Walter flap-style drum sanding wheels... but I didn't see anything on Amazon that was small enough diameter... my previous ones were either 1" or 1.25" diameter. They work great though for putting a nice radius on holes and really making them look amazing.Greg, just an fyi for next time you need to drill one bajillion holes in a first gen floor crossmember thingy...
These are amazing for hole layout purposes. I do all of my rivet layouts with them and they save SO much time and are very accurate.
https://www.aircraft-tool.com/shop/detail.aspx?id=FS01
How tight are those hingepoints? I'd be concerned about any sloppiness or "sagging" of that tool when trying to lay out holes over a long distance. I carefully scribed my target line, then centerpunched all my holes perfectly.... but still, the first drillbit I ran into the cross-sills walked around slightly, and a few of my holes are off by as much as 1/16"!!!!!
I'm going to try to ignore it... which isn't easy to do.Hey now, I didn't drill holes in my cross stills. I did however thought about.
The chassis is sitting at "full bump" right now, but the rear driveline angle last night was only 6.5*... obviously at right height (7" higher) that angle will get steeper, but it's going to be really tucked-up high and the u-joints should last forever at those kind of operating angles.
You should not have to do anything to the holes in the housing, you simply install the stud from inside the housing and use a stack of washers and draw it into the hole. The knurl on the stud will lock itself into the housing. If you were to drill the holes larger then you could potentially have a big problem of the stud spinning and never be able to tighten or remove the 3rd member.
