Brian,
Actually the style line I was referring to is the lower one, not the one at the top edge.
The weird part is that the inner structure of the "skinned" b-pillar lines up perfectly with the door in the first pic. (The second photo shows the door slightly open which is why it looks "off").
When I hung the rear quarter, the crease in the lower "style line" was 1/4" above the spot on the b-pillar where it needed to land, leaving a gap between the b-pillar and the sheetmetal that I'd never be able to squeeze out. It became clear that the simplest way to get those style lines perfect was to simply drop the mounting rail and everything else would fall into place.
I have one advantage that most other people won't, and that is the top of the door is going to be cut off anyway. You can see in the photos I've already cut off the vent wing structure....and the window scraper area is going to be lowered to match the rear bedrail height so I'll have a uniform upper edge. If I wasn't doing this mod, there's a chance that dropping the upper bedrail by 1/4" would have totally screwed things up in that area, but honestly the reflections as I look down the sides now look really consistent and correct from the bedrail all the way down to the bottom of the door.
I'll let you carry on.
