A few more....
Here's a good photo that illustrates why it's such a PITA to clamp a loose Saginaw box to the side of the frame...
The 3 mounting pads are about 3/4" lower than the large lower cap area. It took quite a while to pull accurate center hole dimensions off this box to make an accurate template, but eventually there was a paper template to lay up to the frame...
Finally, the intermediate plate was rendered with a bunch of pre-made 1/4" tabs and some scrap metal. This created a nice flat mounting surface and made attaching to the frame a LOT easier.
The three mounting holes just barely squeak inside the frame dimensions, but it did allow the box to be mounted lower than last time so radiator clearance should be pretty good.
The only problem with working so late into the evening is that sometimes the "math" gets a little fuzzy..... For some reason this plate was tack-welded about 3" too far back (toward the firewall).
OOOPS!!
Guess that gives me something fun to (re)do tonight!
-G
OOOPS!!
-G
). This should produce the desired effect of getting that inside tire to turn more sharply than the outer tire....
