You take valuable time away from your new career as a motorcycle racer to come here with THAT? .....
-G
-G
I don't see why you can't just shoot some Great Stuff foam under those plates...
It comes in yellow, red, white.....heck, if those aren't your colors, you could always get in there with a sharpie and paint the foam.
You could probably use it around the rear ORI's too, when you cut the holes in your bed for them to go through. Water tight, badass and one off.
Just here to help.![]()
It's funny you say this.... I was wondering why you couldn't inject some expandable foam into the cage tubes. Would help reduce some of the resonation from the road and big block.![]()
Could also help the truck float in water crossings! Though with your ground clearance, you'd hafta be crossing a lake...
-- A
Nothing floats better than air.
Shades of The Holy Grail: "What else floats on water?
A DUCK!"
-- A
more witches!!!bridges. Very small rocks!!!![]()
With any luck, I'll be out in the shop tonight so that there will be a better update soon.
Those handrails need more triangulation![]()
You talkin' about Mater in the toybox, or the wheels in the garage?
-G
-G
Had to go back and look... gotta be Mater!
