Sure, if you stuck with the minimum amount of backspacing but if you flipped them you'd be looking for the maximum amount of the same measurement. I don't know what the total width of the rim is, but if it's less than 14" then 7" of backspacing 1 way would work out to less than 7" the the other direction.
right?![]()
You've got it.... but that dropped valley area is pretty heavily offset from the wheel centerline. By my calcs, if you DID flip the hoop around you'd be able to set the wheel up between 2.25" and 2.625" of backspacing depending on where exactly you welded the wheel center to the flat section of the wheel hoop.
Not NEARLY enough backspacing for my project.
It would have a really cool "deep dish" look, but it would stick out of the fenders by a mile....
-G
