2015.06.16 - UPDATE! - BABY STEPS...
Now that I've decided to get the engine running, I spent some time ordering up parts that I'll need for the custom header build.
Originally, I wanted to use the cool LEGO-type modeling kits from icengineworks.com but as it turns out, they don't even offer a kit in the 1-7/8" diameter that I need, and even if they did... by the time I purchased the modeling kit and the special cutting dies (which require a bandsaw that I also don't own!) I'd be into them for around $1400!!!!
And that's just to get the design figured out... I still need to buy all of my stainless tubing, flanges and collectors on top of that.
So I went a different route. I went to Cone Engineering (as recommended) and purchased a simple "builder kit" of 1-7/8" mild steel and their much more reasonably priced angle cutting fixture ($25). This will allow me to basically replicate the icengineworks.com modeling package by creating small sleeved tube sections myself, and giving me the flexibility to turn and rotate them as needed to fit in the available space. I'm looking forward to making this little "DIY Kit"... it's going to be fun, and pretty simple I think.
I also went to stainlessheaders.com and picked up a set of BBC head flanges in 304 Stainless (3/8' thick) and with the correct square-ish port shape to match my iron heads.
Once that stuff arrives (hopefully by next weekend) I can start cutting and figuring a few things out.... and getting some much-needed practice with my new TIG machine.
So while I'm waiting, I decided to get back to the steel wheel/hubcap project since there are a few potential issues I need to remedy before things get too much further along in this build.
Here's one of my current 16.5" OEM pressed centers with the extra mounting flange material welded on, then CNC'ed down to the proper dimension...
As you can see there is some "blending" that needs to occur to hide that extra material that was added. In that photo you can see that the lower flange is blended, and the upper one still has a hard square edge all around it that needs to be flapwheeled and rounded over to match.
The biggest challenge remaining with the steel wheel project is the crazy amount of backspacing that the dropped valley 17" hoops create. Here's a photo of an H2 wheel to show what 5.56" of backspacing looks like on my axle:
The clearances all look pretty good around the steering arm components.. there is 1.5" of space between the outer wheel flange and the steering plate. The problem is that the inner tire sidewall bulges out a LOT more than that, so that 1.5" spacing is about the smallest amount that will still allow the tire to spin without rubbing. (Note: This requires the use of a 3/8" wheel spacer)
By comparison, here's the steel wheel:
I increased the thickness of the wheel spacer from 3/8" to a full 1"... and still lost a full INCH of clearance around the steering plate area.
The tire is definitely going to rub with that setup!
So my options are to replicate the backspacing of the H2 wheel (which requires an almost
2" thick wheel spacer behind the wheel!!!) or use a 1" spacer which will pull the track-width of the truck in by 2" total, and will also require me to modify the steering plate areas until the sidewalls don't rub anymore.
I think I'm going with "Option #2".... Being able to get a narrower track width will be especially helpful on the front axle, since I already have a CRAZY swing path of the wheel/tire due to the portal boxes. This should reduce the craziness and may even allow me to be a bit less aggressive with my front fender clearancing since the tire won't stick out as much. My original design had the tire sticking out roughly 2" beyond the fender arch at all four corners. This new setup will keep them within 1"....
-G
