2015.08.10 - UPDATE! - MORE TIG TIME...!!!!!
It's hard for me to spend a whole day just "practicing" a new skill, but I knew that there really wasn't much point in moving forward until I got a better handle on my TIG welding. I got quite a bit of good advice from everyone here, so I decided to do some experimenting and see if I could get my mistakes sorted-out.
The first thing was to address the most glaring issue. I was using a LOT of stickout on my torch.... I think this was just a habit from MIG where I would start my welds with around 3/8" of wire sticking out from the nozzle before starting a new weld bead.
As you can see from the photo below, my gas lens is pretty small so at 20CFH of Argon flow, I probably didn't have a very good shielding cloud which was leading to those crusty, gray welds.
I pushed the tungsten in so that the stickout was only around 1/8" and sharpened it to the best point I could muster.
I also figured out that my distance from the workpiece was WAY to large as well. This caused the arc length to be a lot bigger than it should be (which has the side effect of making the arc bigger and brighter and making it hard to see the puddle and details of the weld)... Being that far away makes it even HARDER for the argon to protect the weld, so I think the combination of those two things were really hurting my efforts.
This is the TIG setup. I left most of the settings alone and only adjusted the amperage knob. Everything else is basically "off" or at "default" settings.
I had a big pile of 304 stainless coupons from a local metal fabrication shop, so I decided to just sit down and work on one specific skill at a time. With a simple butt-joint and NO FILLER rod, I just practiced getting the arc really close to the workpiece, and trying to see the puddle melting so I could step the torch forward in small steps.
Here's the first coupon:
The coloration was immediately a LOT better... no more dark, sugary gray welds... they were more of a nice shiny orange. I would run about a 2" pass, then stop when I got to the blue Sharpie line and let the purge gas flow for a few seconds once I released the pedal. The gas kept the weld really clean at those spots and the weld (in that last 1/2") was usually a nice silver color.
I did several coupons and went up to 50A to see what that looked like, and I tried a small pass with .030" filler rod, but it was just too much to do at one time so I went back to simple fusion welding (no rod) to continue my practice. One thing I realized is that if you can keep part of the cup against the workpiece and drag it along, its REALLY easy to maintain a tight arc during the weld... that's not to say that I didn't "stick" the tungsten a few times (I DID!!!) but I think that just shows that I was getting more consistent about being in the correct "arc zone" for TIG welding.
Here's a shot of Coupon #5:
Each time I completed a coupon, I tried to study it to see if I could identify the problem areas and understand what caused them. I would occasionally see a "hole" in the middle of a nice weld bead, which makes me think I was moving too fast and not allowing the parent metal to melt and flow into the center completely. So I kept telling myself "SLOW DOWN"!!! By the fifth coupon, it seemed like I was getting a good travel speed and I felt like I was "seeing" the puddle a lot more clearly.
This is the backside of the #5 coupon. It looks like the slower travel speed is really helping me to get 100% penetration (or close to it) even at only 45A in 16GA metal. Considering that I wasn't using any filler rod, this seemed pretty impressive... and it illustrates why REALLY tight fitment joints are important with TIG.
By the end of the day, I was getting pretty bored with just welding coupons so I rewarded myself by tacking a few small bits of the 304 stainless exhaust together and dropping them into place....
As you can see the mild-steel header has been removed from the truck, and I'm now taking notes on the number of bends (and angles) for each exhaust port, so that I can transfer those dimensions to the new stainless material. I did just a small amount of that last night. I feel pretty good about my ability to tack-weld using TIG so even though I still have a LOT of practicing to do, I can at least make some forward progress on the exhaust mock-up as a way to break up the monotony of welding practice plates for hours at a time!!!
-G
