Its looking a lot better with the heat. Have you tried a gas lens? I bought a stubby gas lens kit from HTP and not only is is much shorter but the gas lens gives you better coverage for stainless.
And yes, make sure you poke a hole for the air to escape the purge. Also, the hole should be at the highest point if possible. Argon is heavier than air so treat it like water in the purge.
I like the thin TIG gloves, fit them snug.
For TIG gloves I generally just go with the Harbor Freight super thin goat skin gloves. They are cheap and with the thin gloves it seems when you get them too hot the tips of the fingers shrink so at this price I can treat them more like throwaways.
Heath,
I am realizing that for thin metal, the water cooled torch is probably a waste of money.
I guess I'm still glad I have it for future projects, but I could have saved a lot of money by just getting the regular air-cooled TIG instead. The torch is a WP-20 Weldcraft, and doesn't have any options for a stubby gas lens..... given that I don't really need the watercooling, I think I should probably just buy a different torch that is small, and flexible and more optimized for low-amperage welding projects. Flex-head, stubby lens.... all that stuff! I just don't know how if the connector on the welder side is "standard" across different brands/models or if they are all different?
Stein,
The burn I got was a real oddball situation. I was trying to put small tacks on the mild steel headers to lock the segments together before I removed them. So I had the TIG torch in the middle of that whole cluster of strut/engine cradle/header tubes. It was really hard to get into a comfortable position for welding and I was just "bare handing" it, since these were literally just 1-second long welds..... quick and dirty, or so I thought.
At one point, I lifted the torch out-of-position while it was arcing to the exhaust tube and I accidentally touched the .030" filler rod to the tungsten, where it immediately fused-itself and got stuck. The filler rod is 36" long so the other end was flopping around and at that exact same moment, the flopping end touched the underside of the engine cradle tube creating a perfect ground for the 45A flowing into the tungsten!!! That entire filler rod INSTANTLY turned bright red and welded itself to the engine cradle, and my fingers couldn't let go of it fast enough to get away from all that heat! It was pretty damn scary and painful, but I eventually dropped the torch and the circuit was interrupted but by then I had already gotten my "3-finger tattoo".
Lesson learned. Wear gloves (ALWAYS) and use smaller lengths of filler rod when working in tight spaces.
-G
