It was a rainy day yesterday, so there was no chance to get the truck out of the garage to turn it around.
I did the next best thing, and moved the truck back a few feet toward the garage door to create more working space around the front of the truck.
To begin on the driver's side header the steering shaft needs to be installed to "block out" that space from the tube routing. I took a few measurements and photos so confirm what I think I need to order:
At the steering box: 3/4" diameter.... (
Splines with a huge flat side machined in "D-shape" design)??
And at the steering column: 3/4" diameter, 36-spline:
I'd really like to get those parts ordered, so if anyone can confirm that I've named these correctly I'd appreciate it.
Moving on to the part that I can do now, I spent some time flaring the tubing to match the square-flange at the cylinder head.
I has having a LOT of trouble with the tubing splitting at the welded seam. It turned out that the location of the seam on the forming die makes a BIG difference. When I lined up the seam in the middle of the "flat" side of the square it would split every time. When I put that seam in the corner instead it seemed to work MUCH better... I used a little bit of cutting fluid on the inside of the tube as well just to reduce the friction during the forming process.
The fitment to the flange was insanely good (Hella Tight!) so I threw a few tacks on each segment, and bolted them up to the engine.
On this side, it seems like I can replicate the #8 design for #7, and the #2 design for #1... the trickiest one looks like it's going to be #3... just because of how close it dumps out to the steering shaft....
I won't know for sure until I get the REAL parts installed and start putting some tube in there!!
-G
