Nice upgrade! You should be able to notice that.
It's not an update on your truck, but at least it's not another update on a hospital visit!
Did I miss why you chose foam over fiberglass?
I've already got an attic full of moldy R-39 fiberglass..... that was my previous attempt that failed.
Apparently, the non-vented roofdeck combined with the high temperature differential caused moisture to accumulate as the cool air inside the garage met the hot air that was driving through the insulation in the summertime. All the paper got wet and eventually turned black and moldy. No Bueno.
I've been slowly removing the fiberglass as I go.... a vented roof deck is a much better way to deal with the summer heat, but the effort involved to create air passages with wooden strapping and foam sheets is not trivial. At least I've really getting all the small air gaps sealed along the way. It remains to be seen if a leaky R39 fiberglass is better than a well-sealed R-24 foam sheet setup... certainly, I will have solved the moisture issues.
I always have the option of doing ONE more layer of foam sheeting over the top over everything. The nice part of that is that it will lay on top of the rafters completely, so I don't have to to any fussy fitting and cutting into 14" wide strips like I've been doing. Just slay full-size 4'x8' sheets across the whole mess and foil tape the seams and that will put me at R-36.
We'll see....
I really want to get back to truck building, and exit the home renovation sideshow as quickly as possible.
-G
Ah, so the top side of the sheets are vented to outside? Those gotta be pics as good as all the other stuff.
Makes perfect sense now.Look at this pic....
It's a little hard to tell, but the rafters are 2x10's and there is a visible space between the plywood on the roofdeck and the first layer of foam. It's basically a 4" air channel that will run cooler air from the soffits (once I cut vent holes and install bug screens!) all the way up to the peak of the roof.... I've got a big thermostatically controlled fan up there, so when the air is hot it will turn on and draw the cool air up both sides of the roof and push the hot air out.
-G
Cool watch
It's amazing how much nicer it is to just flip the switch and have the machine come up to full speed immediately.... no drama, no fuss. And no more excuses not to get back to work!!!
Of course by the time I pay for powdercoating, I'm probably spending more for mild-steel than I would have for stainless anyway.
Looks like a lot of progress made outside the rig which should help the rig soon.
I feel you on the sander circuit, I went through the same thing with my little 110 air compressor for most of the truck build. You had to drain the air tank real low before you turned it on or it would trip the breaker.
Can't you wire that sander motor for 220V operation? It will likely drop less voltage and startup even faster yet, and you can use the same 10/2 wire you ran just change it in the breaker panel.
As for the fuel tank, 11 GA? Holy canoli batman, is this a fuel tank/skid plate in one?
Powdercoating inside the fuel tank might prove difficult, especially in the corners.
