Wait, your not putting in a lift? I guess I missed why you opened all that up then?:dunno:
So you did this for a lift?
Actually, I did it because of this issue...
Last time I tried to do a full suspension-cycling test, the rollcage hit the ceiling and I couldn't get the axles to fully bump/droop out the way I wanted. With this much open space and being able to park the truck dead-center in a 2-bay garage it should be a lot simpler to get the truck up on some cribbing and really see what the suspension is doing and if I still have any interferences.
(PLUS: I'll be able to take cool build photos without a bunch of ugly posts in the way and blocking the view.)
-G
Super flex. I’d get about half that. But I’m still on leaf suspension. Looks good either way. I need to also go through my garage and figure out better storage.
-G
What, without ugly buckets did you say?
@blazinzuk
You can see that even in the NH garage, I was utilizing that upper mezzanine space for clear bins to store excess parts. SO much better than trying to use those pull-down folding ladders and less awkward to get materials up / down from that space. The new garage has a cable hoist/basket setup that will allow me to lift bins and then slide them along a second I-beam into the storage area so I don't even have to carry them up a ladder with me. Safer.... no broken bones, etc. :)
-G
2019.03.11 - UPDATE! - WALL CABINETS & ANKLE BUSTERS...
Hello.
It's been a while. Work, Life, and all that.... but I'm happy to report that I'm starting to find more hours lately to get back into the shop.
There's still lots to do to get it ready for "real" work, so I guess we should get started on the update.
First things first... the upper mezzanine storage area is now finally fully sheathed and ready for polyurethane to seal up the plywood.
The first coat actually got applied about a week ago, but the Varethane was so smelly that it permeated the entire house and got me into big trouble with the rest of the family. So the next couple of coats will have to wait until the weather is better and the rollup doors can be left wide open with lots of fans blowing for a day or two. Once the poly is dry, it will be a massive cleanup of the downstairs garage area and probably one of the most dramatic visual changes to the workshop... since all of the clutter will be put up high and out of the way and for the first time since arriving in Texas, the entire garage floor will actually be available to move around in. :waytogo:
While waiting for the weather to improve, the attention is turning to the back wall of the garage when the cabinets and workbenches should go.
I've been looking at a company called NewAge Cabinets for the upper and lower cabinets. They sell some cheap 22GA stuff, but their Pro Series 2.0 and Pro 3.0 are a thicker gauge metal that seems to be well-regarded on sites like GarageJournal.com etc. They sell them at Costco and HomeDepot so I'm going to make an effort to go see them in person, pull out the drawers and get a feel for the overall quality. It's a balancing act between price/function and this is an area where you can spend a small fortune, or a large one depending on how demanding you are about the quality and features you want. :yikes:
Planning for cabinetry is actually more of a challenge than it first appears. Obviously, the water softener is right in the prime real-estate and will be relocated out of the way, but the less obvious problem is the "step-up" area of the concrete roughly 36" inches from the wall.
This creates a really awkward standing position when trying to retrieve tools from the toolbox and will be even MORE of an issue if a workbench is installed along that wall... You can stand in place, but you'd never be able to open up a bottom drawer without falling backwards off that cement ledge and twisting or breaking an ankle.
The idea that is being considered is to build up an additional platform to increase that platform area to maybe 50 - 56" deep ( standard cabinets are 22" deep from the wall). Some kind of pressure treated lumber anchored to the concrete... lots of liquid nails, bracing and a couple layers of plywood to make it super solid. Then lay down heavy rubber interlocking industrial pads over the whole thing to hide the new construction and blend it all together? :thinking:
Anyway, you can really see the issue with the blue tape (showing the cabinet layout) and how treacherous the entire thing would be if something isn't done. It would be nice to be able to set up the TIG welder at a workbench area like that with a comfortable stool (for welding up a set of headers for example) :) But falling off the back of that lip in a stool sounds like another trip to the emergency room to me..... and I really don't want to be "that guy" again.
-G
Replumb the water softener. With the walls are already open, it's easy enough.
Yep. I already talked through it with a local plumber. A little PEX and it's going about 10' straight UP into the loft area. No reason to give it such a "prime" location on the best garage wall.....
-G
Hello.
-G
You ain't efin around with that work space.:bow:
And good news, supposed to be pretty darn nice this weekend.
Do you have your ac done yet?
