Those inner axle seals require full differential dis-assembly to install. Are your current seals leaking? When you slide the shafts in to install them, they slide through the seals on each side of the pumpkin. If you look closely at your axle shafts, near the splined end you should see a smooth(er) area and that is where the shaft rides on the seal. Make any sense?
Wrong parts suck...I don't know much else that can be as frustrating. It's enough of an issue that I routinely compare old parts to new until I'm thoroughly satisfied new = old. I'm glad you finally got that sorted out!
