I'd pass on the 750 carb too. No choke is BS, and it's too big.
Why mechanical secondaries?
Martin
I missed that info about the heads. Thought he was using the stock heads.@joedragrace It doesn't look like the intake manifold you suggested works with his '87-'95 heads.
Other than the electric choke, is the 670cfm better suited for his engine than the 750cfm he listed?
If you wanted to use a spread bore carb, this looks like a good option. You eliminate the problems associated with throttle/transmission kick down linkage, fuel line hookup, and vaccumI really appreciate it guys. Looks like consensus opinion is that Joedragrace's recommendation on carb is way to go!
