'72 K5 - Where do I go from here?
New (longer) E-brake cables are still about 1" short. Of course, I already installed them, so there's another $50 in the garbage. I got about 6" of lift from my set up (roughly). Anyone with a 6" lift found the emergency brake cables that work? I thought about moving the bracket, but that looks like it would be tough as there is another bracket mounted just behind it. I could rig something up.......but visions of my Blazer rolling off a cliff don't make that feel like a prudent move.
Bummer man! I have 6" of lift but I was able to use the stock cables until just recently when I moved the axle back 1.5"
They just barely don't fit so I might be interested in yours. :thinking:
This gives me an idea: http://zoneoffroad.com/zone-offroad-products-emergency-brake-relocation-bracket-ford-f150/f5608
If the mounting point were about 3" lower, the cables would work. I don't see why I can't get some 1/8" plate steel and make something like that to drop the mounting point. Hell, I can even use the stock hole for the cable as one of the holes to bolt it.
Looks so simple I am pretty sure that even I can make it! (famous last words....) Guess I know what I am doing next Saturday.
Pretty much what I am thinking (below). From here (if you care): http://www.americanmuscle.com/roughcountry-liftkit-perform22-0913-4wd-manu-install.html
Sweet, I don't have to take apart those damn drum brakes again!
When I ordered my E-brake kit from In-Line Tube, I had them add 3'' inches of length to the stock length. Worked great!
Sweet. (UPDATE BELOW)
UPDATE on 6/19/2017
bp71k5 Nailed it! Yesterday I was moving the Blazer around and at one point realized I had just pushed it, without much effort, after forgetting to release the parking brake. I drop down, look under - both brackets bent. I thought about straightening them and welding on some angle braces........then I thought about how long I have been working on this thing, how much money I have spent, etc........so out came the brackets and the cables. Brought a cable to work with me today, called Inline Tube - They no longer make E-brake cables. However, I found a place called Control Cables (http://www.controlcables.com/cables-2/) just up the road in (what I call) The Greater LA Area. The guy who helped me (Vic) was very helpful (and patient), told me exactly what measurements he needed, and they are charging me $32.00 per cable (good price in my opinion). I'll have the new cables by this weekend.
Live and learn........it's all good - Forward!
BP - Works like a champ. It's 1/8" steel plate, seems pretty damn solid. I set/released the E-brake 10-20 times to test - no issues. Hell, drilling through that plate was no joke, it's some damn solid steel.
Back from 2 weeks on the East coast (work and play). Always good to walk the National Mall, visit Smithsonian, Harpers Ferry, Antietam, etc.
Anyway, needed a break from wiring, so I put in the new steering box and mocked up everything. Thoughts on this angle? Does not seem too extreme, but comparison to my 'before pic' shows it pretty flat.....and that is a drop arm for the lift (bought together).
Looks good to me.
There is another thread around here somewhere talking about drag link angle and the jist was that a little downward slop is a good thing.
Somebody else will be where I am in the future - learning (for me about everything to do with our Blazers, but right now I am specifically referring to engine building, parts buying for that endeavor, etc. I came across this excellent write-up and wanted to share so that anyone who knows as little as I do will become enlightened (a bit) about distributors/vacuum advance........
There appears to be a lot of conversation on timing, vac advance, distributor tuning and, in general, hacking up a perfectly good ignition system to compensate for a poorly tuned carburetor.
Here's an interesting article on vacuum advance written by a GM Engineer:
As many of you are aware, timing and vacuum advance is one of my favorite subjects, as I was involved in the development of some of those systems in my GM days and I understand it. Many people don't, as there has been very little written about it anywhere that makes sense, and as a result, a lot of folks are under the misunderstanding that vacuum advance somehow compromises performance. Nothing could be further from the truth. I finally sat down the other day and wrote up a primer on the subject, with the objective of helping more folks to understand vacuum advance and how it works together with initial timing and centrifugal advance to optimize all-around operation and performance. I have this as a Word document if anyone wants it sent to them - I've cut-and-pasted it here; it's long, but hopefully it's also informative.
TIMING AND VACUUM ADVANCE 101
The most important concept to understand is that lean mixtures, such as at idle and steady highway cruise, take longer to burn than rich mixtures; idle in particular, as idle mixture is affected by exhaust gas dilution. This requires that lean mixtures have "the fire lit" earlier in the compression cycle (spark timing advanced), allowing more burn time so that peak cylinder pressure is reached just after TDC for peak efficiency and reduced exhaust gas temperature (wasted combustion energy). Rich mixtures, on the other hand, burn faster than lean mixtures, so they need to have "the fire lit" later in the compression cycle (spark timing retarded slightly) so maximum cylinder pressure is still achieved at the same point after TDC as with the lean mixture, for maximum efficiency.
The centrifugal advance system in a distributor advances spark timing purely as a function of engine rpm (irrespective of engine load or operating conditions), with the amount of advance and the rate at which it comes in determined by the weights and springs on top of the autocam mechanism. The amount of advance added by the distributor, combined with initial static timing, is "total timing" (i.e., the 34-36 degrees at high rpm that most SBC's like). Vacuum advance has absolutely nothing to do with total timing or performance, as when the throttle is opened, manifold vacuum drops essentially to zero, and the vacuum advance drops out entirely; it has no part in the "total timing" equation.
At idle, the engine needs additional spark advance in order to fire that lean, diluted mixture earlier in order to develop maximum cylinder pressure at the proper point, so the vacuum advance can (connected to manifold vacuum, not "ported" vacuum - more on that aberration later) is activated by the high manifold vacuum, and adds about 15 degrees of spark advance, on top of the initial static timing setting (i.e., if your static timing is at 10 degrees, at idle it's actually around 25 degrees with the vacuum advance connected). The same thing occurs at steady-state highway cruise; the mixture is lean, takes longer to burn, the load on the engine is low, the manifold vacuum is high, so the vacuum advance is again deployed, and if you had a timing light set up so you could see the balancer as you were going down the highway, you'd see about 50 degrees advance (10 degrees initial, 20-25 degrees from the centrifugal advance, and 15 degrees from the vacuum advance) at steady-state cruise (it only takes about 40 horsepower to cruise at 50mph).
When you accelerate, the mixture is instantly enriched (by the accelerator pump, power valve, etc.), burns faster, doesn't need the additional spark advance, and when the throttle plates open, manifold vacuum drops, and the vacuum advance can returns to zero, retarding the spark timing back to what is provided by the initial static timing plus the centrifugal advance provided by the distributor at that engine rpm; the vacuum advance doesn't come back into play until you back off the gas and manifold vacuum increases again as you return to steady-state cruise, when the mixture again becomes lean.
The key difference is that centrifugal advance (in the distributor autocam via weights and springs) is purely rpm-sensitive; nothing changes it except changes in rpm. Vacuum advance, on the other hand, responds to engine[/URL] load and rapidly-changing operating conditions, providing the correct degree of spark advance at any point in time based on engine load, to deal with both lean and rich mixture conditions. By today's terms, this was a relatively crude mechanical system, but it did a good job of optimizing engine efficiency, throttle response, fuel economy, and idle cooling, with absolutely ZERO effect on wide-open throttle performance, as vacuum advance is inoperative under wide-open throttle conditions. In modern cars with computerized engine controllers, all those sensors and the controller change both mixture and spark timing 50 to 100 times per second, and we don't even HAVE a distributor any more - it's all electronic.
Now, to the widely-misunderstood manifold-vs.-ported vacuum aberration. After 30-40 years of controlling vacuum advance with full manifold vacuum, along came emissions requirements, years before catalytic converter technology had been developed, and all manner of crude band-aid systems were developed to try and reduce hydrocarbons and oxides of nitrogen in the exhaust stream. One of these band-aids was "ported spark", which moved the vacuum pickup orifice in the carburetor venturi from below the throttle plate (where it was exposed to full manifold vacuum at idle) to above the throttle plate, where it saw no manifold vacuum at all at idle. This meant the vacuum advance was inoperative at idle (retarding spark timing from its optimum value), and these applications also had VERY low initial static timing (usually 4 degrees or less, and some actually were set at 2 degrees AFTER TDC). This was done in order to increase exhaust gas temperature (due to "lighting the fire late") to improve the effectiveness of the "afterburning" of hydrocarbons by the air injected into the exhaust manifolds by the A.I.R. system; as a result, these engines ran like crap, and an enormous amount of wasted heat energy was transferred through the exhaust port walls into the coolant, causing them to run hot at idle - cylinder pressure fell off, engine temperatures went up, combustion efficiency went down the drain, and fuel economy went down with it.
If you look at the centrifugal advance calibrations for these "ported spark, late-timed" engines, you'll see that instead of having 20 degrees of advance, they had up to 34 degrees of advance in the distributor, in order to get back to the 34-36 degrees "total timing" at high rpm wide-open throttle to get some of the performance back. The vacuum advance still worked at steady-state highway cruise (lean mixture = low emissions), but it was inoperative at idle, which caused all manner of problems - "ported vacuum" was strictly an early, pre-converter crude emissions strategy, and nothing more.
What about the Harry high-school non-vacuum advance polished billet "whizbang" distributors you see in the Summit and Jeg's catalogs? They're JUNK on a street-driven car, but some people keep buying them because they're "race car" parts, so they must be "good for my car" - they're NOT. "Race cars" run at wide-open throttle, rich mixture, full load, and high rpm all the time, so they don't need a system (vacuum advance) to deal with the full range of driving conditions encountered in street operation. Anyone driving a street-driven car without manifold-connected vacuum advance is sacrificing idle cooling, throttle response, engine efficiency, and fuel economy, probably because they don't understand what vacuum advance is, how it works, and what it's for - there are lots of long-time experienced "mechanics" who don't understand the principles and operation of vacuum advance either, so they're not alone.
Vacuum advance calibrations are different between stock engines and modified engines, especially if you have a lot of cam and have relatively low manifold vacuum at idle. Most stock vacuum advance cans aren’t fully-deployed until they see about 15” Hg. Manifold vacuum, so those cans don’t work very well on a modified engine; with less than 15” Hg. at a rough idle, the stock can will “dither” in and out in response to the rapidly-changing manifold vacuum, constantly varying the amount of vacuum advance, which creates an unstable idle. Modified engines with more cam that generate less than 15” Hg. of vacuum at idle need a vacuum advance can that’s fully-deployed at least 1”, preferably 2” of vacuum less than idle vacuum level so idle advance is solid and stable; the Echlin #VC-1810 advance can (about $10 at NAPA) provides the same amount of advance as the stock can (15 degrees), but is fully-deployed at only 8” of vacuum, so there is no variation in idle timing even with a stout cam.
For peak engine performance, driveability, idle cooling and efficiency in a street-driven car, you need vacuum advance, connected to full manifold vacuum. Absolutely. Positively. Don't ask Summit or Jeg's about it – they don’t understand it, they're on commission, and they want to sell "race car" parts.
From here: http://67-72chevytrucks.com/vboard/showthread.php?t=274806
This is what I am looking at for the top end (based on recommendations from engine shop). Appreciate any inputs. The heads are '87-'95.
Shopping CartCheckout
Part #PriceQtyTotal
Edelbrock 2104 - Edelbrock Performer Intake Manifolds
Intake Manifold, Performer, Dual Plane, Aluminum, Natural, Square/Spread Bore Flange, Chevy, 5.0/5.7L, Each
EDL-2104
$229.41
Update
$229.41
Remove
@joedragrace It doesn't look like the intake manifold you suggested works with his '87-'95 heads.
Other than the electric choke, is the 670cfm better suited for his engine than the 750cfm he listed?
