Surprised you don't have one of these yet. All the cool kids use them...
Would that not cause torsional issues with the structure of the body? I'm picturing it twisting out of shape.
I thought that was rot at the seams. Putting one of these bodies on a rotisserie would scare the shit out of me. Something with a full roof, no worries, other than that, I would be paranoid.
Ok, if I soak an area with brake cleaner first, I can scrape very gently and still get it clean.
I found a nice surprise. Leave it for the body shop to fix when they do bodywork/paint? It's the only visible rot I have found.
Sorry, I should have explained better. I am not putting A/C or heat back in. Don't need it here, and I hate that huge doghouse in there. However, i don't want to weld something on, just in case I ever decide to go back to The Great State of Texas (I bought land when stationed there) and add the A/C back in.
Don't they still use an A/C compressor on the engine? I know everything else fits under the dash, but I thought they still needed a compressor.Weld it up!
Odds are good that if you ever add A/C in the future you would go with a more modern setup like Vintage Air which works a lot better and takes up far less room. It doesn't even require a hole in the firewall since the entire unit is located under the dash near the glovebox...
-G
