andyblack
Registered Loser
Okay, I see how they work now. I guess the longer spring just does a little different than the regular length. Looks like it's working quite well.
Did you use stock height 52s or lift spring 52s? What brand of front spring hanger did you use? Good to hear that it's drivable on the street. That's one thing I would be worried about if I ever do the swap. You need to post some pics of how the ride height looks now. I've seen a lot of trucks that were lower in the front after the swap. Where did you get the longer slip yoke from?
Sounds great.Did you use stock height 52s or lift spring 52s? What brand of front spring hanger did you use? Good to hear that it's drivable on the street. That's one thing I would be worried about if I ever do the swap. You need to post some pics of how the ride height looks now. I've seen a lot of trucks that were lower in the front after the swap. Where did you get the longer slip yoke from?
I'm thinking that with a few more unique mods, your Blazer could get nominated for GM of the month!![]()
Have you drooped the pass front tire out yet? That shaft doesnt look like it has much extension left.![]()
and missed the shot were i almost flopped it. They have a bunch more rock gardens out wich is nice.
all that flex makes your tires look small lol
Eric runs 42's on his 60 with stock shafts/joints/hubs, and a Detroit. pedal control is key! He was breaking stuff right and left with 44's though.
