73 K20....crossmember time
So roughly $650 for the bender and 1 die. Then you have to come up with a stand and its still manual. I wonder how hard it is to bend .120 wall dom manually?
I'm not bending anything manually, I'll buy the swag kit with a HF hydro ram. Then I'll use one of my extra engine stands to mount it all. It's basically the same setup Chris uses.
Damn. It adds up though. I dont think i could swing basically $1000 for a bender. Not unless i loaned it out to recoup. I have enough mild sitting around i should just make one.
My buddy and I use his manuel bender all the time. Really not bad at all.
yeah i think with a cheater bar its probably ok. The only disadvantage is its probably harder to know where your at degree wise but if you have more than one person...which never happens with me lol.
Yeah, there's no way I would spent that kind of money right now. That's why I talked my buddy into it :D:waytogo:
Oil base for the paint. I'll try to get a picture of my hoops. Steering shaft is a non-issue. Custom made. Hoop mounts to the outside near the booster and inside near the box, strattling the shaft o_O
