I guess its just a few bolts and it comes down?
Im not sure what to do about the sender with the hard lines on it though. Dont want to break anything.
When I pulled mine to swap to the TBI sending unit I was able to reach between the floor and the top of tank to disconnect everything. This was with the tank straps unbolted, sitting on a jack and slightly lowered. It is hard to do. You are sitting basically upright under the truck. I'm a small guy so it wasn't too tight. There are the hose clamps that use pliers to remove. Not the hose clamps that tighten with a flat head/nut driver. Hopefully they are positioned on the hose so you can remove them like that.
Other then the lines. Don't forget the ground wire that goes to a bolt on the drivers frame rail (1/2 socket I do believe). And the wire going to the sending unit. It just pops off the sending unit.
