wetoolowdingbangow
Took the white wire straight to 12 volts and it does the same thing. Starts then dies right after. I have no clue.
This still has to read rpm input. Is that wire disconnected or damaged?
If you don’t have rpm signal that’s likely your problem. It won’t start at all if you had low voltage when cranking.
Did you revisit the programming just to see if it reverted to a different setting?
Have a spare HEI?
Do you have a separate tach? Wondering if you see that move at all?
Man what a bitchGot it. Program was corrupt. Reprogrammed and right to life she goes. One problem down!
Man what a bitch
