docjake
I like the textured red I think you did a really good job
Just when i thought I might not have to deal with wiring for a while after rewiring the '73....oh well. at least i know what i'm doing now![]()
(starting college at the University of Texas)
Thats the spirit!
The '73 looks great. I like the way the paint came out.
Still think it needs a 4" lift![]()
Go Horns!
Big Longhorn football fan
Good luck at college,man
Thanks. And yes, I am fairly sure that if any serious wheeling is to be done, a lift is in order. no clue when that'll be though haha
Whoo! Hook 'Em!!! that's awesome, and thanks again
) and put the positive on the hot post on the alternator and the other on the negative battery post, I was getting voltage. So my first thought: Bad ground. Pulled the headlight switch so I would know when it had power again. I check the most immediate and vitally important one, the big gauge cable from the neg post to the engine. and by check, I mean whack it with the nearest wrench... and taa-daa, we have power.
Turns out that paint on the bracket it's attached to was causing a state of intermittent insulation, causing the loss of power. So that was an easy fix. No more non-start/no power issues.
looks pretty cool, though this motor will probably never need that much airflow.
). Got back on the road and headed back towards Lufkin, so the Honda could go to a shop and hopefully I wouldn't fry the trans.
No stereo, heat not working, No OD haha. Needless to say, first leg of the trip went awesome, truck did great, and I was loving driving it.
. Over the break, I may dedicate a day to just retorqing and checking bolts on the whole truck. Tightened all those up, poured in some stop leak additive for good measure, picked up a couple more quarts of oil. As of last time I looked at the truck, oil leak seemed to have either stopped or slowed considerably.
my s10 had a similar problem where it out of no where on the highway started missing and running like ****. Turns out that the plug were highly foulded. Not sure why it happened all of a sudden, but just throwing an idea at you.
BTW I like the design of your locking storage/sub box.
I would bet its either
- a fouled plug (or plugs) or
- plug wires burning on exhaust
My Suburban started running like dung on the freeway a few months back. No power, sputtering and vibrating. A quick check of the wires showed that the two front-most wires on the passenger side had popped out of their looms and were laying on the manifold,melting away.
Went ahead an popped in a set of new Autolites and a set a wires and it purred like a kitten
I had a weird one on a SB Chevy where a single pin in the dist cap fell out while driving. It wasn't easily noticeable, since the wire stayed in place on the top half of the pin. The bottom half, however, was laying under the rotor when I found it. The car lost a lot of power and started missing and popping under the slightest load. I've also had a distributor slip while at full throttle, but that killed the engine with a bright flash out the exhaust. Yours still may have slipped, but less than mine did. Just throwing out a few more possibilities for you to check.
Wow, I hope you looked at all of them.
You might want to check compression (rings) and valve seals. That is a lot of junk for just fuel.
