kinda Ram Charger-ish.
Thanks, though you best not be sneering at my door locks!I mean, it's not like I have keys to the locks, but it's not like I'll need them either
Anyway, I like to think that if we can't have fun, it ain't worth doing!
-- A
I agree completely. I wasn't trying to insult you, this stuff really is entertaining to me. I also enjoyed your engine stand/door holder.
Martin
kinda Ram Charger-ish.![]()
Do you not have a topper for it?
Plymouth trailduster, I believe is the " other" model.
Got any more plans for the cage?
May I recommend some sort of crossbracing in the roof of the cage.
I have seen cages without the roof bracing fold over more than a foot in a hard roll. I have even seen them fold over 6" in a very mild roll.
Now mind you those are both full roll overs not just pop it on its side.
It would also help to stiffen up the B pillar if you added a brace from the seat belt bar going up on the b pillar.
... but you have valid points. Might just be a middle ground somewhere.
I wonder if the smaller pieces behind the seats provide more strength in this orientation, or would it matter if they were switched around to be more like gussets, with the lower end at the outside of the cage and the upper end at the center? Such an orientation would work better in my instance for various reasons, but as I look at it, I suspect that this provides more crush resistance at the corner.
Its all about spreading the load out. In a side roll one of the first things to be hit is that b pillar. So how I have them braced is spreads the load to the seatbelt bar. I intend to add some more gussets underneath it too.
How I have my roof spreaders will help transfer a side load too.
Think about how the cage will be loaded and then try to maximize load transfer, while minimizing unsupported areas. You do have to be careful though any cage can end up looking like a jungle gym I actually think mine started to look like a jungle gym but I put as few bars in there as I felt I could.
Did you notice Aaron that I am not saying anything about your TOP secret?
I can keep a secret you know.![]()
I was gonna start on that, but it looks like I gotta make up my mind about the cage first...
And while it's not rainy, which is lousy weather to work in outside, the warm time of the day is so short ... grr...*i dont know anything about cages* but: in one picture you have crossing bars behind where the driver seats would be. would it be better to make 2 verticle bars towards the inside shoulder of each seat, leaving a gap between them to get into the back from the front if need be? or did you scrap the idea all together?
At that point I'll sort out what I hope will be a workable compromise between strength and comfort -- and yeah, the ability to get around the seats into the back is on the list.
