Had to pull the rear bumper off to change it up a bit. I strive to keep my Master Plan in mind when I'm working on the truck, so I don't end up un-doing and re-doing work ... but it happens occasionally.
Switched to LED backup lights in the oval trailer style (more on this in a bit) on the bumper wings. Two passes with the right size hole saw:
and then two straight cuts with the cutoff wheel
Et voila, the gasket and light just drops right in. Also welded tabs to the center for the tire carrer and hinge points to the top outers. (These latter may be slightly overbuilt as I had some 1/2" plate of the right width in the scrap pile.
Taking pictures of the lights in the dark never turns out well (see below.) The LED's aren't bad, though. While not as insanely bright or as widely dispersed as the halogen, they are markedly better than the factory ones in both regards.
Yes, I like lights.
-- A
)Taking pictures of the lights in the dark never turns out well (see below.) The LED's aren't bad, though. While not as insanely bright or as widely dispersed as the halogen, they are markedly better than the factory ones in both regards.
Yes, I like lights.
-- A
and I'll be checking it periodically.
