76 Blazer Project thread Updated 6/19/15 Long over due updates
time for some updates, so i left my truck up north for a few weeks and came back to find it like this
So in the process of getting it out of the snow this happened
This truck will be seeing a lot of work the next few weeks, i have a D60, Crossover and 52's in the plans
Gotta love working out in the cold. I just replaced the converter to muffler gaskets on my fiance's Cougar about an hour ago in my parents unheated garage.
Nice rig for 2K. $hit, I wish mine looked half that nice! Mine's still a work in progress. You know, I thought I was wrong once,...............but I was Mistaken!
so i am starting on my Dana 60 Axle for my truck i should have it done in the next few weeks
here is the collection of all the parts i need to put the 60 together
here is one of my axle u joints together and the parts to put the other one together
The clean cups ready to get grease and needle bearings
The first cup with the seal and all the bearigns installed
The finished Ujoint ready to go
I started to tackle the king pins on my 60 today they are a pain
this king pin is not wanting to break loose
the caranage on the snap on break bar from the king pin
one if the king pins actually came out pretty easy
I got some more work done tonight, the old front suspension is out
The Old D44 and 4 inch springs
Greasy 350, ill have to clean this before i am done with this swap
Steering Brace getting fitted in place
the nice bend in the bottom of my frame
The old D44 and springs
well today i made a little more progress, i removed all the rivets that i needed to for the 52's and cleaned up the steering box area to find small cracks that i had to drill and will weld in before i put the brace on
The nice crack can be seen on the lower right bolt hole for the steering box
The twisted cross member removed so it can be replaced
All the empty space from the removed crossmember
I opened up the rear end to see what i had in there and its a gov-bomb, so looks like its time to weld it up
I have made some progress in the past few days, i got all the old brackes off the frame and the extra ones off the donor frame that i have. I got one of the sides for the 52's mocked up and started to put the seals in my D60 just waiting on the lockright that is on back order to put the axle all together
The New holes drilled in the Frame for the New DIY spring eyes
The Beefy DIY shackels and 52 inch springs installed
Below a Picture of the installed 52 inch spring and the steering box brace welded in
I figured its time for a update, These pictures are pretty old but the most current i have, the truck is back on the road ill take some pictures tommarow of the track bar setup i made and the rest of the 52 swap
The old twisted Cross member is removed
The first 52 Spring is mounted
My truck joins the one Ton Club
Some more pictures of the D60 swap, i finished it a few months ago and have been driving it to get all the bugs out
Cross Over Steering using a sky arm
And the Engine Swap begains
The New Engine all painted up and ready to go in
New Transmission all painted up nice ready to go in
Old 350 getting ready to come out
here are the pics of the trac bar that i made, i am going to add some more reinforcement to the top mount while the engine is out
More Progress, things went pretty slow in the afternoon i had to run around a lot to find part and buy a bunch of tools because the ones at my house got locked up
5.3 Sitting nicely in the frame rails bolted to the engine mounts
The Clearance issues with the engine cross member were taken care of with a grinder
Plenty of room back here
