76 K5 Blazer Chalet - Put the ol girl out to pasture, literally.
chalet2506
CK5 Huge Member
Skeddadlin
chalet2506 submitted a new Build:
In the beginning......
http://coloradok5.com/forums/showthread.php?t=177461
Read more about this build here...
Any reason I can't use regular bolts for the hood to hinge mount? In the 2 years since I took the hood off the Chalet I seem to have lost the original ones.
Torque specs for the castle nut on the tie rod ends?
Thanks. :D
Regular bolts should be fine but make sure to use a washer. Most hood to hinge bolts are a flanged head bolt with serrations to help keep the bolt from becoming loose.
Torque spec on Tie rod castle nuts is 45 ft/lbs.
Crap. Was up on the engine hooking up the vacuum line for the tranny modulator, bumped some wires behind the distributor which shorted and burnt a couple fusible links in that harness, I think.
Truck no worky again. :o
Thanks for the answers.
Better to happen at home rather than on a road trip somewhere with possibilities of a fire and being stranded.
I guess that's why everything in the manual starts with "1. disconnect the negative battery cable."
I was thinking the same thing, I didn't bump it very hard, looks like the insulation where they spliced the wires was about gone.
I promised myself I'd wait til done to post pics, but have been driving around the parking lot for a couple days and am stoked. Found the hood bolts, I was smart enough to bolt them back in the hood back in 2008.:crazy: You can see the 2 years, or 1/4" of accumulated warehouse dust on the windshield.
Just need to tie up some loose wiring, bleed the brakes again, mount the hi-lift, put the hood back on and she's road ready. Of course there's still little stuff, but I'm bout 99% there.
ideally, you use washered bolts...
Don't forget your stealth "black / 'can't-find-it-in-the-woods' green" color decal for the back door. :D
Well, my e-brake cables out of the axle wouldn't reach the little brackets to the frame. So I had a buddy build me a couple little 5" steel, drop brackets(see pic).
I tightened the slack in the cables, and the pedal is nice and tight, but the brake won't hold. Looked and my brackets are bending a little, but I wouldn't think that would be a problem.
As I have all new drum brake hardware, is there something I need to do to adjust the e-brake?
Also open to a different idea on the brackets, the only thing I can do is to take them off an a weld a perpendicular stiffener onto them.
