DeviousK5
I had the same cable not reaching issue, made a bracket , hated it. Called NAPA 14$ later a 7 in longer cable was delivered to the shop, perfect now, and no flexy ground clearance killing bracket
Do you think the flexy bracket is the reason the brake won't set?
yep, the cable housing needs to be rigidly attached to something, otherwise you just pull that bracket closer to the drum when you set the brake rather than the other way around.
Yes.Did all the Chalet's have the pop up top?
