I emailed Kirk @ fitech with a question about vapor lock with the Fuel Command Center. Didn't take him long to respond which is definitely good.
My question
Hey Kirk I have a quick question about the fuel command center. I'm wanting a simple quick way to supply my EFI and considered using the command center. My only concern is vapor lock. Especially with it being a return less system. I do a lot of low speed rock crawling and sometimes the temperature outside is brutal. How does the command center work in high temp situations?
His reply
Hi
the pressure is only 5 or 6 psi, the FCC will perform well all the way up to the point where the fuel starts to boil.
Anything after the high pressure fuel pump, you will not have any vapor lock.
Keep the fuel command center from any major heat source, and keep it under 200°.
Anything else let me know
