It's thin and it'll squish. I'm also impatient so it won't be dry when I bolt it in. LolDo you want bedliner where the mounting surfaces touch?
NiceIt's thin and it'll squish. I'm also impatient so it won't be dry when I bolt it in. Lol
I ran out of 2wd crossmembers to chop up! HahaNice
Did you duplicate your effort for your southern brother?
2wd drive conversion floor?
BenchseatcovermafiaAre you still running a bench?
Yeah I am.Are you still running a bench?
2wd floor sucks...2wd drive conversion floor?
You're doubler clocked up 2"?
Thanks! I am using a normal shift boot but I am leaving an access hole so I just need to build a cover for that.Nice work the floor looks excellent! What kind of cover you found to do for the shift tower? Wouldn't a normal shifter boot cover it quite well?
