Sounds good dude. Didn’t think about that side of things. Was more concerned with the body of the joint pivoting and maxing out the ball.On your rear shackles jam nut is a must. Threads are not zero tolerance. You will wear the threads out. It might take a while to do but eventually the threads will fail. Jam nut will prevent any up and down movement.
So a jam nut is a must
