Well, no luck so far. Nick and I changed the oil out for fresh 10W30, double checked all connections got the camcorder going and gave it a spin with a splash of fuel in the carb. Nothing. Some more fuel, nothing. So, we pulled #1 plug and I cranked while Nick checked for spark. Good strong spark...OK, that's something. Another splash of fuel, backfire through the carb. Hmmmm.
Being a little curious I busted out the compression tester. 5 revs on and #1 was ~27 psi.
. Move to #2...35 psi.
I feel it's turning over a bunch slower than it should be, so we hook up the jumper cables to my K5. #1 now reads almost 40 psi. I guess that's something. We put the batt charger on the '57 and went in for dinner. I originally figured that would be it for today. Nick went home and I broke out my manual and ran across a part mentioning lash needs to be adjusted anytime the valve train has been apart (it has been apart). OK, why not...
With the VC off I start with #1...except I have an exhaust valve opening. Awesome, I have the firing order on the cap 180 degrees out. So I re-thread the cap, then adjust all the valves. I busted out the compression tester again, and #1 is now 60 psi. For giggles I threw some more fuel into the carb and hit the key, and it made some starting noises but never caught. I'm gonna sleep on it and let that battery charge really good. I figure it might even get the compression up to~90 psi if it cranks at the right speed, and that will surely help it want to start better.
So, still no vid, but it's made more noise tonight than it has in 49 years.
