77 The Black Truck "Ratbag"
About two weeks with diesel...all I did was pour a gallon down the carb. And yeah it turned over super easy.
I did pull all the plugs and sprayed some wd40 in the cylinder's first and tried to turn it over with a 3 foot breaker bar on the crank balancer bolt. also tried rocking it back and forth in high gear.
It will be the weekend before I even look at it again. Covered in snow right now. Fock that sh!t.
Snowed good there?
Fockin winter here again too FFS!!!!
Its definitely been one of our more mild ones as well....after the last 2, this was welcome!
Can`t get the c10 to spin fast enough to start. Had tons of battery power and spark... maybe its the starters fault. :thinking:
I was going to try and light it up with either but I don't have any right now.
yeah, maybe a bad starter...
Double check the firing order, Nick had all the wires off at one point, and well...neers. :ignore: :haha:
Sure! Now you tell me! :haha: I think the carb is not helping do anything either, and I don't want to try the quad off Ratbag on it. And Jesse @Bowtie85 stole my spare! :angry1: :D
I`m done with it...I started disassembly of the front end already.
I want the nice unmolested wiring for my 77.
I kinda think that carb didn't like the diesel, or the diesel washed some crud into various areas...who knows. I got my Pontiac turning over with a key (aka screw driver). I'm gonna drain the old oil and try and fire it up in a little while. I promised Nick I would make sure he was here for it...so I'm gonna see if he wants to come over and run the cam corder.
Well, no luck so far. Nick and I changed the oil out for fresh 10W30, double checked all connections got the camcorder going and gave it a spin with a splash of fuel in the carb. Nothing. Some more fuel, nothing. So, we pulled #1 plug and I cranked while Nick checked for spark. Good strong spark...OK, that's something. Another splash of fuel, backfire through the carb. Hmmmm.
Being a little curious I busted out the compression tester. 5 revs on and #1 was ~27 psi. :yikes:. Move to #2...35 psi. :doah:
I feel it's turning over a bunch slower than it should be, so we hook up the jumper cables to my K5. #1 now reads almost 40 psi. I guess that's something. We put the batt charger on the '57 and went in for dinner. I originally figured that would be it for today. Nick went home and I broke out my manual and ran across a part mentioning lash needs to be adjusted anytime the valve train has been apart (it has been apart). OK, why not...
With the VC off I start with #1...except I have an exhaust valve opening. Awesome, I have the firing order on the cap 180 degrees out. So I re-thread the cap, then adjust all the valves. I busted out the compression tester again, and #1 is now 60 psi. For giggles I threw some more fuel into the carb and hit the key, and it made some starting noises but never caught. I'm gonna sleep on it and let that battery charge really good. I figure it might even get the compression up to~90 psi if it cranks at the right speed, and that will surely help it want to start better.
So, still no vid, but it's made more noise tonight than it has in 49 years. :waytogo:
