The main problem is that everyone talks about "bolt on" and how easy it is...
...until you get under your 80's diesel K series and discover there's stuff sorta in the way and the frame and crossmember are slightly out of alignment and there's a big glob of mud in the way and blah blah blah. Couple hours later and you're done. I actually had to enlarge the hole in the crossmember so I could bolt mine on.
That area on both of my trucks has LOTS more stuff down there than the old 70's K5 or whatever ORD used for it's pictures and write up.
Your way is definitely the easiest.
