Dave If it is truly 15" then you are fine. Basically fast doesn't want you daisy chaining of of any other power source. And you shouldn't loose your tune unless you clear the flash.
Yes it is....in this pic the POS post is on the right, and the master switch is under the botttom left of the battery. 1/0 cable from batt to switch. then it would be the 10ga from the switch to the supply to the FAST comp.
That should be fine.
I wired mine completely separate from everything else to ensure no voltage change to the computer but your a lot closer to the battery than mine.
You should be fine IMHO.:waytogo:
good eye Ash....that's to cover the hack body work and Angle iron underneath from a panel replacement sometime in its past!!!
That OSB serves as a backer for a sheetmetal panel to "finish" the wheelwells off inside!
Any feedback on how those BBC L&L headers worked out? Would you buy them again?
Although I don't have a bunch of time on them they like everything else on the truck gets run hard
They do not leak , I tightened the header bolts after the initial breakin and haven't had to touch them since
The only issue is the dr side collector has interference w the shackle
I do Jess
Gotta get the hydro lines to stop spewing and I think I may have fried my PS pump....then bleed the system which I hear can be a bear with the hydroboost and get my belly plate on still
I want to make a run up Warn valley!
must haves:
Repair Hydro line leaks... DONE
Build trans skid plate and crossmembers...
Install and wire XD9.5 Winch...
then ready for BundyHill!
DSCN0655 (1024x576).jpg DSCN0656 (1024x576).jpg hydro line leak repaired, but pump is whining like a bastard now! Will be replaced over the winter.
Glad to have Kert, John, Kelly, Luke, and Nate all down to help with repairs/upgrades Friday evening... got a belly and trans pan skid made, but I think it may have been the culprit to cracking the transmission case. It was tight against the 205 and probably pushed it up some when tightening the bolts from the skid to the frame causing the t/c to be tilted up some putting stress on the transmission, then the hard throttle blasts of drag racing and other tom foolery led to a broken case....I was done for the day at Bundyhill.
DSCN0657 (1024x576).jpg DSCN0659 (1024x576).jpg DSCN0660 (1024x576).jpg DSCN0658 (1024x576).jpg DSCN0661 (1024x576).jpg just Kert and I left Sunday afternoon, so I decided to put the small tires on it to get it in the shop, as it will be there for a while now!
As I hit the lugnuts with the impact, the wheel studs turned on 5 of the 8. So after some investigation and head scratching we came up with a plan to get the nuts off the studs by welding a rod to the wheel studs, slipping a socket with a welded on piece of pipe to it, then holding the rod with vise grips and removing the nut with a pipe wrench on the pipe/socket...worked like a charm...plenty of penetrating oil used also.
John (Kellyjohn) showed me the correct type of lugnut to use on these kind of wheels...made by McGard, which should cure this problem for good...Kelly has them on her Dodge and has many miles on them without issue.
Now I need to resize the wheelstud holes in the hub/disc and find some bigger studs to press in again.
I feel terrible about this!!!!!
I'm so sorry that the work we did under your rig was likely the cause of the break Dave......:eek1::doah:
Totally thought the armor work under there was bad a_$ !
It sure looked great with the bow-ties plasma cut in it.
not to worry John, and don't think I was pointing the finger at you or Kert, certainly not the case!....I was the one who took the dimensions to Kert for that t/c plate...and I was the one who said bolt it up tight to the frame, not thinking it would move the t/c at all...so its all on me, my design was off a bit and in haste to get something to cover the trans pan (because I thought we would be running up Warn Valley?) I was insistent about getting it done...besides, the doubler had to come out again anyway to fix a rattle IN the 205 and a leak between the doubler and the trans....and I already have another 400 case sitting on the shelf!
better find another spare soon, just incase that wasnt the culprit. hope its easy enough to swap it all to the other case.
Hey John....found these studs which look like they will engage the hubs much better than the old ones, which weren't engaged in the hub much at all....
thread size-9/16"-18 ...knurl diameter-.621"...knurl length-.890... length under head-3-17/32"... shoulder length-1-5/16"
and these nuts...It doesn't tell what diameter the washers are, but do these look like the ones you have on Kelly's truck?
http://www.mcgard.com/index.php/auto...gory_pathway=0
I wondered if you knew what length the studs were that you have on her truck...I will try to duplicate that....what do you think?"
Here is what i was able to come up with for you Dave.
The short stud is what we replaced, it's 2.25'' from the inside of the shoulder
It only has a 1/4" band of "splines"
The long stud is the replacement we used, 3'' long from inside of the shoulder
This style like what you are looking at have a 7/8" long band of splines/
I wasn't able to find the nut info from Kelly's truck (on paper) but was able to find the wheel lock nut info.
Standard nut PN# 06204-9/16
You can probably cross reference the lock # also to confirm.
the washers are 0.745" ID x 1.062" OD x 1/8" thick
looks like these are the only ones that will work....John does this match the description of the ones on Kelly's truck?
http://shop.mcgard.com/chrome-duple...ize-set-of-8-lug-nuts-and-8-washers?sku=62822
Be sure to check the thickness of the wheel vs the length of the nut shank. I learned with my Weld wheels that both come in varying sizes so you have to make sure the nuts match the wheel and don't bottom out before getting tight against the wheel.
Right, with the studs that came with the disc/hubs from GMpartsdirect I have 1" of threads showing past the wheel mounting surface, according to McGard the nut has to engage in length equal to the diameter of the stud...John has the same setup on Kelly's Powerwagon, so I will duplicate what he has....I also have to be sure they will mount both sets of wheels...the aluminum slots and the steel beadlocks...I don't think the steel beadlocks will be an issue as the lugnuts are open ended I believe.
I'm not talking about thread engagement, I'm talking about how far the nut shank (the part inside the wheel). If the shank is longer than the wheel is thick then the nut will bottom out on the hub before clamping the wheel. The shanks are available in different lengths. Also the steel vs aluminum wheels will need different style nuts.
Wouldn't the beadlocks probably just use standard acorn style lugnuts? I'd just find some good, regular lug nuts and run those for the beadlocks.
