Fresh snow is so beautiful...especially with swamper tracks in it. I had mine out a few days ago - backing up a trailer in 2 feet of snow is not easy!
Paint it purple :)
Purple is just so wrong, just so wrong:eek1:
I bought the paint two years ago, Its still sitting on the shelf in the shop....It won't be an earth shattering moment, just that it will have some real paint on it, instead of primer.
Already bought the paint...and its taken its frankentruk identity with the Ryoken Green Zinc color and school bus yellow/hemi orange cage so that will stay.
I need a plug for my EZ EFI controller connector...a bit different than typical GM stuff, any ideas for this type of plug?
Dave, what is it controlling? I have a big illustrated parts book at work I may be able to find something in
Call FAST? :dunno:
sent them an email...no response???
Looks like the plug for the handheld display
Correct...I want to keep the dirt/moisture out of it.
Looks like a newer O2 sensor plug.
Martin
Looks different than my 99 6.0 plug, any idea what years/applications?
Now, that I'm back from work, I have time to compare. It is a Delphi 150 series sealed connector. Here is the mating plug. http://terminalsupplyco.com/Store/Product.aspx?pc=12110293
Seals
http://terminalsupplyco.com/Store/Default.aspx?CAT=DEL030050&PCAT=53143#Categories
Terminals
http://terminalsupplyco.com/Store/Default.aspx?CAT=DEL030030&PCAT=53143#Categories
The problem with Terminal Supply is you have to buy in bulk.
Let me find another vendor that may sell the one plug as a kit.
Thanks a ton for the input JD....
I need exactly what I have pictured above....that pic is the plug in end from the FAST controller which I assumed is female. I need one just like it except sealed at the wire end to keep the dirt and moisture out of the Brain box plug pigtail....from what I read, its called a male?
