Hey Dave,
Nailed it!
Again!
just what I had in mind Kert!
I was hoping it was your new grille with a location to wrap up recovery things like straps... :D
That would be cool Colby, got another style in mind for the grille...more tube and expanded metal!
Ah didn't know it was that big.:waytogo:
Those little holes are 16" on center for mounting to studs!
and 3/16" diameter for screws. Just throwin' that out for some scale. Its a pretty big piece actually.
You suppose thats a 14 bolt?:thumb:
a SF14 maybe, it don't stick down far enough for a FF..:haha:
been working in the shop lately, but not on the Maiden....time for a compressor upgrade....wondering if/when the ole single stage oiless POS compressor would blow another rod...probably at the worst time...so out with the old:
And in with the new:
60 gal. 5hp. two stage 175psi.= 15.5 cfm
So I started rerouting plumbing, then that ballooned into rewiring, then cleaning out the shop to make more room, get rid of some JUNK and reorganize the rest of the stuff that stays. Should be here next week sometime...once I get the shop put back together I need to get on the Maiden heavy...headed to Kerts place in March to pick up a bunch of stuff.
sold it for 250....
sold some air hose, and a paint gun for 150....
putting all that on the new one!!!!
got the new compressor in this week, set in place, wired, and started piping.
So much quieter now!
Running a filter then a regulator, then out to 4 drops....
Put in an outside port w/ some outlets too....something I wish I had done since I built the shop.
Looks really nice!:pimp:
Now you should be able to get a lot more work done now.
Stainless fittings dave??? DAAAYYYYUUUUUUMMMM :thumb:
Adam, this is one reason why pharmaceuticals cost so dam much, everything in product contact is stainless...and they throw a ****load of it to scrap....well they clean up pretty good I must say! Some have some boogered threads, others maybe a bunch of sealant or attached to a bad valve or flange, but a little time spent on them makes em usable for me!
A shop without air seems so unfulfilled:whistle:
